Cube Drill - PAX - bug (And workaround)
Posted: Thu Apr 04, 2019 3:00 pm
by Herman Moller
Hello All,
We have been doing some work on Cube Drills in PAX and have noticed the following bug :
If you have a cube drill and only have a row defined in the cube view it will return the right view but will be blank.
To get a drill through to work in PAX you need to have at least 1 dimension defined in the row and 1 dimension defined in the columns and then it will return values.
Herman
Re: Cube Drill - PAX - bug (And workaround)
Posted: Thu Apr 04, 2019 4:26 pm
by PavoGa
Here is another thread on this same topic from a few weeks ago:
https://www.tm1forum.com/viewtopic.php?f=3&t=14287
Posted: Thu Apr 04, 2019 6:06 pm
Herman Moller wrote: ↑Thu Apr 04, 2019 3:00 pm Hello All,
Herman
This could well be because the primary axis in MDX (and the Rest API?) is columns. Unless there’s a dimension defined on columns then it’s not a valid view in the MDX.
