TM1 - External URL - PA2.0.4 - Contributor Grid Fails to Load
Posted: Mon Apr 01, 2019 3:45 pm
Hi Gurus,
We are trying to implement External URI in TM1 -in PA 2.0.4 and when I try to open contributor grid, it's blank. "External Server URI" portion of configuration is used when users are not on intranet. I have changed some code in pmpsvc_config.xml, fpmsvc_config.xml and tm1web_config.xml.
Am I missing any other configuration for contributor?
I checked the source code of blank page there's some error to read as below.
Thinking it's a certificate error, we turned off the certificate and contributor loads all views, from fiddler trace code is like below.
I Googled and found link https://www-01.ibm.com/support/docview. ... wg21998395.
In the link, under section "Import the CA Certificates Into the Java cacerts File", I tried to import our cert, with no success.
Can anyone suggest an idea to work? Please let me know if you have any questions.
Thanks in advance.
Paul.
<script language='javascript'>
appId=null;appErrMsg='javax.net.ssl.SSLHandshakeException: com.ibm.jsse2.util.h: PKIX path building failed: java.security.cert.CertPathBuilderException: PKIXCertPathBuilderImpl could not build a valid CertPath.; internal cause is:
java.security.cert.CertPathValidatorException: The certificate issued by OU=Go Daddy Class 2 Certification Authority, O="The Go Daddy Group, Inc.", C=US is not trusted; internal cause is:
java.security.cert.CertPathValidatorException: Certificate chaining error';
</script>
appId='XXXXXXXX-XXXX-4c4a-87f0-31ece5600193',nodeId='[}tp_tasks}7214893b-719b-4c4a-87f0-31ece5600193].[XXXXXX.XXXX.XXX]',multiOpen=false,nodeViewIndex=0
</script>
Thanks in advance.
Paul.
