I have an issue to determine spreading functionality.
Generally I'm using tm1web or perspectives. Trying to put numbers on consolidated elements and as result I expect value equally spread to all leaf elements.
It's working perfectly if all n-elements contains some numbers or all of them are 0s.
The case is that if some of them are 0 and some are different than 0, spread functionality avoids zero elements.
Is there any option to determine spread functionality to always spread to all n-elements?
Please help if there is any option like that. I couldn't find anything on this subject.
regards
Spread functionality
lordohlord
- Version: 10.2
Re: Spread functionality
'Equal Spread Leaves' is probably the spread option you want - the last choice on the right click menu in Architect.
lordohlord
- Version: 10.2
Thank you for answer. Yes that is the right option from architect/perspective point of view. It is working as expected.
I have more doubts with tm1web. How to set it up to use such option in tm1web by default.
Not by using right-click menu but just input data directly into consolidation cells.
regards
regards
As far as I am aware there is no ability to change the default spreading option.
If you don’t want to use the right-click menu you can show users how to work with shortcuts, for your example it sounds like LS*500 would work - this would spread 500 equally across all leaves (the * indicates it should include even the 0 value cells.)
Or since you want an equal spread it could be easier for users to press C to clear the data and then just type the value they want, it then defaults to equal spread as the underlying data is empty.
While we are discussing a technical solution, can you tell us why you would like to have this, even more as the default choice of data entry ? I mean, in what kind of cubes / applications / levels of aggregation do you see fit for such a requirement ? I am supporting many TM1 models and the one thing that pisses me off the most, is when users overwrite a 0 value at consolidated level... unless it's purposeful (like all level 0 cells and then a consolidated month element gets the data that is to be spread over 3-6-12 months).
