TM1WEB 2.0.6 Number Issue
Splashmore
OLAP Product: PAL
Version: 2.0.6
Excel Version: 365
Post by Splashmore »
We have a problem with the websheets on IBM Cognos TM1 Web.
After the update to the version 2.0.6 of Planning Analytics all the numeric values of our websheets don't follow anymore the format of the Dimension Editor (from Architect or Perspectives). They follow some regional settings of the browser and to that they add the format of the excel sheet (for example, in Chrome if the format in the excel sheet is 1.000,00 , it will be shown in the websheet as 1000,00000 or in another Chrome version 1,000.00 (adding a 000 at the end or changing comma and dot, but this is variable and depends on the browser version or on the browser itself). The problem we have is that we only can use Chrome and we need a fixed format for all users, which has to be with 2 decimals separated by a comma and a dot as thousands separator.
Can anyone please help me to find a fix to this problem?
Thank you in advance.
Re: TM1WEB 2.0.6 Number Issue
Splashmore wrote: Tue Mar 19, 2019 2:30 pm We have a problem with the websheets on IBM Cognos TM1 Web.
Unfortunately, an active form cannot do what you have requested. Whenever you put multiple dimensions in the columns you get the intersection of each columns dimension subset (whether via a subset or MDX query) against each other. You can't selectively not use some of the intersections (which is what you are asking for).
paulsimon
Version: PA 2.0.5
Post by paulsimon »
I think what Tom is getting at is that if you have a Web Sheet that is really an Excel Sheet with an Active Form then it will always display values according to the Format Area of the Active Form. Have you just upgraded from a 10.x version to PA? It is possible that the conversion of the web sheets, particularly if they were converted from .xls to .xlsx format has done something to the format in the Excel Sheets. I would check the Format Area in the Active Form to see if it is still what you expect.
I'm sorry about my post. It was actually a reply to a different question and I posted it on the wrong message.
Splashmore
OLAP Product: PAL
Version: 2.0.6
Excel Version: 365
Thank you for the answers. However, it seems to be a bug in version 2.0.6. The bug occurs in both Active Forms and DBRW formulas.
Splashmore
OLAP Product: PAL
Version: 2.0.6
Excel Version: 365
Confirmed by IBM...
PH05317 SINCE 2.0.6 LOCALIZED NUMBER FORMATTING IN WEBSHEETS IS BROKEN
PH07538 TM1 WEB AFTER UPGRADING FROM PA 2.0.4 LC TO PA 2.0.6 LC THE FORMAT OF THE NUMBERS IS BROKEN
Bakkone
Post by Bakkone »
As posted this is a known defect. Hopefully it will be fixed with 2.0.7 due to be released now in March. But IBM sais the websheet rendering is done by a third party, so they wont promise anything.
I do love how this shows that IBM ships stuff without even testing on a computer with a different regional setting tho. Very nice...
In your case a workaround would be to set Chrome to always use english to render the page.
https://www.wikihow.com/Change-the-Defa ... gle-Chrome
Bakkone wrote: Wed Mar 20, 2019 5:18 pm
That is not the first time: https://www.tm1forum.com/viewtopic.php?f=3&t=14417
