VBA code determine if user logged in
mitch23
Post by mitch23 »
Is there a way to determine through VBA whether a user is logged in to TM1? I have a reporting spreadsheet with a lot of VBA code, some of which I only want to execute if the user is logged in.
Re: VBA code determine if user logged in
mitch23 wrote:Is there a way to determine through VBA whether a user is logged in to TM1? I have a reporting spreadsheet with a lot of VBA code, some of which I only want to execute if the user is logged in.
There was a TM1User worksheet function introduced with 9.1 SP2. From your profile, it should be available for you:
The TM1User worksheet function returns the user name of the current TM1 user.
If the current TM1 user is not connected to a server, or if the specified server is not running, TM1User returns an empty string.
You can use the Application.Run method to access the worksheet function via VBA.
Its not really clear what exactly you mean or from whose perspective you are meaning but in either case I think no vba is necessary.
If you mean that YOU as an administrator only want to do certain processes if a user is logged in you can do this just by reading the ClientProperties cube with a DBR.
If you mean certain vba should only be run by THE USER if they are logged in you could just put in a simple check to a DBR reference, if the cell returns a KEY ERR then the user is not logged in. (or if you want you could do a test with the NCONNECT macro function).
Hope that helps.
