Unable to move Active forms from one server to another server manually
valletchuman
Post by valletchuman »
Hi Folks ,
i tried copying one file with .xlsx.blob from Applications folder in one server to another server while migrating that object . but after server restart i can see the objects but i couldnt open that file it was saying links are not available . Do i need to copy any other files to that server along with BLOB ? can anyone suggest .
Thanks ,
Val
Re: Unable to move Active forms from one server to another server manually
The corresponding file in the }Externals folder ?
valletchuman
Yes . It worked Wim .
Thanks a lot,
Val
valletchuman
I could Now open the form . but unable to select element wherever subnm used . is there any objects i consider moving other than one in applications and externals folder ?
babytiger
Post by babytiger »
Is the destination instance name same as source instance name? If not, you may need to update the excel file (in }externals) with the correct instance name.
MK
valletchuman
yes instance names are different . i used Tm1Server& in all SUBNM fuctions
valletchuman
Hi Folks ,
How can i use server instance reference in active forms . any idea . i couldnt use Tm1server& in place of server instance name in active form . any suggestions ?
valletchuman wrote: ↑Wed Mar 06, 2019 8:28 am Hi Folks ,
The method described in this post is a pretty common way of setting up workbooks/websheets to automatically set the server name to the instance currently logged into.
valletchuman
Thank you so much
