HI Team,
We have an issue where one of the web report is not showing the values using Internet Explorer browser.
The values are appearing when the report is opened using Chrome and also logging in using the perspectives.
I have checked using admin log in and the result is the same.
The issue has been identified as browser specific, Please advise how can we fix it.
User has cleared internet cache and re-booted the machine but still not fixed.
Only particular field value is missing, everythig else looks ok on that report, the other fields from the same cube has no issue.
Neelima
Tm1 web report issue
- jim wood
- Version: PA 2.0.7
Re: Tm1 web report issue
Moved to the correct forum.
CellPutN
- Version: 10.2.20500.75
Can you please provide more detail such as TM1 version or Report type (Slice or Active form ) ?
Neelutm1
- OLAP Product: COGNOS TM1
Tm1 version 10.2.2.2 fix pack 7
Active form.
and I noticed actually the vlaue is there but only visible when I take the mouse to that cell and when I double click on the cell it is showing the text by moving the arrows up and down..
strange it is not happening for shorter values on the same filed. looks like field length is causing the issue.
Neelima
Active form.
Neelima
