What is vcsch.log in the log folder ?
Pete
What is vcsch.log ?
CellPutN
- Version: 10.2.20500.75
What is vcsch.log ?
- 2019-02-12_21h51_36.png (364.39 KiB) Viewed 9978 times
Re: What is vcsch.log ?
I'm guessing you have Pulse installed?
On install Pulse modifies or creates the tm1s-log.properties file to create this separate log file where GlobalCollection, File & System loggers are monitored. It is managed in a separate log file to not pollute the default tm1server.log file.
Pulse monitors this log for system events.
CellPutN
Yes we have Pulse installed!
Thanks a lot Lotsaram, always helpful !!
Niko
- Version: PA 2.09 / TM1 11.7.00000.42
- Excel Version: EXCEL 2019
Hi,lotsaram, i want to know how to close this log generatelotsaram wrote: ↑Wed Feb 13, 2019 6:35 am I'm guessing you have Pulse installed?
From tm1s-log.properties you can comment out or remove the following section.
You also need to remove the reference to "SRC" from any loggers being written to multiple files and remove completely or comment out lines for loggers that are being written only to SRC.
Note: if Pulse is running on the server then it would simply recreate these entries in tm1s-log.properties so there would be no point doing it.
log4j.appender.SRC=org.apache.log4j.SharedMemoryAppender
log4j.appender.SRC.File=vcsch.log
log4j.appender.SRC.MaxFileSize=10 MB
log4j.appender.SRC.MaxBackupIndex=0
log4j.appender.SRC.TimeZone=LocalNote: if Pulse is running on the server then it would simply recreate these entries in tm1s-log.properties so there would be no point doing it.
