Hi ,
I wanted to write a calulated value to all values in time dimnension in a TI ,
is there a simpler way to do it or it has to be cellputn for all elements .
I cannot use a rule for performance issue and bringing in as a ti .
Write a calculated value to all elements in a dimension
- Steve Rowe
Re: Write a calculated value to all elements in a dimension
Fundamentally yes if using TI, you may want to look at spreading.
Not much to go on here Manu but you should look at your design / requirements IMO.
Writing the same value "to all values in the time dimension" would seem to be an odd thing to need to do, can't this be an attribute of the element in the dimension?
- OLAP Product: IBM TM1, Planning Analytics
- Version: PA 2.0.5
Thanks !! Will store it in an Attribute value and then use it . Thanks!!
