Unable to delete the last element of the dimension through TI process
spartan
OLAP Product: IBM cognos
Post by spartan »
I could not able to delete the last element in the TM1 dimension, i am using dimensionelementdelete function in TI process.
For example.. if their are a,b,c,d in a dimension i can able to delete each element one by one, but i could not able to delete the last element, if I try
to delete all elements at a time i could not able to do that as well.
If i delete the last element it is not deleteing, through ti process if i add a element the last element is updated by the added element.
I can update,add the elements but i cant delete all the elements at a time and cant delete last element as well.
Could you help me through this.
Re: Unable to delete the last element of the dimension through TI process
Read the request for assistance guidelines and post your code.
Next to posting your actual code, are you sure you want to physically delete elements ? Is that appropriate in your model, or would you rather want to delete the cube data linked to the elements instead of the elements themselves ?
