Guys,
Can I have a picklist populated from two other dimensions based on some conditions? For example if condition 1 is true then populate the picklist from dimension A else populate the picklist from dimension B.
Thanks in advance.
Picklist from Two Dimensions Based on Condition
Re: Picklist from Two Dimensions Based on Condition
Yes, create a picklist cube with a rule, rather than a picklist attribute.
