DEL Command is not working in TM1 Process
My24
Version: PA 2.0
Excel Version: Excel 2016
Post by My24 »
Hi all!
I am trying to create a file in prolog and and delete the file in Epilog of a process.
But when I am trying to delete the "test.txt" file, the process is aborted and gives the error of "The system cannot find the file specified."
Also when I run the command of DEL "C:\Program Files\ibm\cognos\tm1_64\samples\tm1\PlanSamp\test.txt" from cmd, the file is deleted but I want to delete the file with TI.
Could you help me about this problem?
The code is the following:
Prolog:
vFilePath = 'C:\Program Files\ibm\cognos\tm1_64\samples\tm1\PlanSamp\test.txt';
ASCIIOUTPUT(vFilePath, '');
EXECUTECOMMAND('TIMEOUT 5', 1);
Epilog:
vCommand = 'DEL '|'"' | vFilePath| '"';
ASCIIOUTPUT('CommandLog.txt', vCommand);
ExecuteCommand(vCommand, 1);
Regards.
Re: DEL Command is not working in TM1 Process
Del is a command which is internal to the command line processor.
The usual way around this is to create a generic batch file with a parameter, such as:
del %1
which then allows you to use ExecuteCommand to call that batch file. The second argument that you pass (separated by a space) is the name of the file that you want to delete, which will be passed into the %1 variable.
2 remarks.
You can use the function AsciiDelete.
If you want to use ExecuteCommand with creating a text file, create the file in the Prolog tab and execute it in the Epilog tab. Then delete the temporary text file again.
Wim Gielis wrote: Tue Dec 25, 2018 7:27 pm 2 remarks.
Good point.
Wim Gielis wrote: Tue Dec 25, 2018 7:27 pm If you want to use ExecuteCommand with creating a text file, create the file in the Prolog tab and execute it in the Epilog tab. Then delete the temporary text file again.
I was originally going to mention that but then on further examination that didn't appear to be what they were trying to do. The AsciiOutput looks like it's just debugging code (note the name CommandLOG) rather than trying to create a batch file. If it is, though, it would run into two additional problems:
(a) It won't work with a .txt extension, it would need to be a .bat one; and
(b) Unless the quote character is modified either by using a command in the prolog or in the data source tab, if available, the command would by default come out wrapped in double quotes.
And a command that is wrapped entirely in double quotes is going nowhere.
My24
Version: PA 2.0
Post by My24 »
Thanks a lot for your responses.
Both of two methods successfully work!
Also
vCommand = 'cmd /c DEL '|'"' | vFilePath| '"';
ExecuteCommand(vCommand, 0);
would work with no need for text files.
Take care with using the ExecuteCommand function with the 1 parameter set, very occasionally DOS will hang and then your TI will get stuck.
Unless you have a good reason use the 0 qualifier and then your TI won't get stuck.
Niko
OLAP Product: IBM Cognos TM1
Version: PA 2.09 / TM1 11.7.00000.42
Excel Version: EXCEL 2019
Post by Niko »
My command that is wrapped entirely in double quotes is going nowhere.
i want to delete the folder ,subfolder and all files in that folder.
So it doesnot work , i want to solve the problem
i input the script below in the windows cmd manually ,it works well.
rd/s/q D:\backup\Sales
then i input the script below in the TI Process manually , execute failed , server log show : "The system cannot find the file specified".
i guess the quotes Cause the result , so who can help me? thankyou first.
[Prolog]
sBackupDir = 'D:\backup\Sales';
sDelCmd = 'rd/s/q '| sBackupDir ;
[Epilog]
ExecuteCommand( sDelCmd ,1);
Have you tried uisng CMD /C first?
sDelCmd = 'cmd /c rd /s /q '| sBackupDir ;
Also, not seeing spaces between rd and the parameters.
BR, George.
Niko
Post by Niko »
gtonkin wrote: Sun May 15, 2022 5:08 pm Have you tried uisng CMD /C first?
Thank u first.i will try later today,and i will share the result to you.
Niko
Post by Niko »
Niko wrote: Mon May 16, 2022 1:08 am
Thank you very much. I add cmd /c before the command,it works well.And i want to know the reason why i should add cmd /c ,i am very confused.
MarenC
Post by MarenC »
You say you want to delete all files in the folder, but when I read the rd docs, it states:
You can't delete a directory that contains files, including hidden or system files
Did you consider using powershell? So this in your TI instead:
sDelCmd = 'Powershell Remove-Item -LiteralPath "FolderNameHere" -Force -Recurse';
I read somewhere that it is better to use ExecuteCommand with 0 instead of 1, but use sleep in conjunction, so
ExecuteCommand( sDelCmd , 0);
Sleep(1000);
Happy to be corrected on this latter point.
Maren
Niko
Post by Niko »
MarenC wrote: Mon May 16, 2022 7:31 am Hi,
Sleep(1000);
Maren
Thank you for your advice, because I want to wait for the completion of the deletion command,and then to delete the BAT file containing the deletion command. if I delete the BAT file before the command is executed completely, i guess i will not be able to delete the folder successfully. So i am suprise for that if i execute the bat file ,sleep(1000) and delete the bat file immediately, whether the command can be executed successfully? Look forward your reply,thank u first.
MarenC
Post by MarenC »
You don't need a BAT file, you just add that code into the TI process, and forget about the batch file.
Simply running the TI should do the deletion.
Maren
Niko wrote: Mon May 16, 2022 7:18 am ...
CMD /C should create a new command line instance/context (new process) and run the command there for you. This may change some of the environment variables/inheritance etc. I typically start with CMD /C to start a new process which runs and terminates when complete.
BR, George.
Niko
Post by Niko »
gtonkin wrote: Mon May 16, 2022 10:42 am
OKay,i have understood that , thank u again.
MarenC
Post by MarenC »
Glad someone has! ;)
