Can anyone confirm that MTQQuery actual works in current releases, I'm using 11.1.1.36.
According to documentation it should be on by default.
but I couldn't see anything in TOP to indicate it working (I can with MTQ, with work units spinning up).
Added explicit parameters
MTQ=-1
MTQQuery=T
No restart since they are dynamic and still no joy.
Am I missing something? I'm assuming this works around the need to build the view before querying to get the MT bit working? My processors stats are staying at 13% with no other activity in the DB, so its not an issue with Top not reporting.
If I cube view my data source I see work units.
Haven't looked super hard for an issue at my end yet, if I'm doing it wrong let me know..
QQ !
MTQQuery
- Steve Rowe
MTQQuery
mvaspal
- OLAP Product: tm1
- Version: 10 2 2 - 2.0.5
Re: MTQQuery
https://www-01.ibm.com/support/docview. ... wg27048366
Just guessing here.
Maybe this is still relevant and MTQQuery=T is not enough, and you have to follow the rules as explained in this technote?
Just guessing here.
- Steve Rowe
Re: MTQQuery
Thanks mvaspal, I'd not found this tech note when searching.
Having to have Skip Consolidated Values unchecked seems to be a pretty odd requirement but I'll test when I get a chance. I would habitually use a L0 subset rather than "All" + "Skip Consolidated Values" in my view definitions.
Now wondering if there are no C levels in the view if this parameter will do anything, i.e. The parameter is intended to accelerate the calculation of C level elements from Ns but has not impact on the calculation / delivery of large amounts of ruled N levels.
Will update when we get round to testing, won't be rushing though as I'm less confident that this is going to help too much.
