Websheet function: find the Group of a user
mnasra
Version: 2.0
Excel Version: EXCEL 2013
Post by mnasra »
Hi experts,
I need to change the color scheme of the Active Form based on user security. (grey if no access, white if access is permitted)
I can find the user (tm1user() function)
But the security is per group.
How Can I find which group this user belongs to?
thanks
PS: Maybe I am complicating something that is very simple
Micheline
Re: Websheet function: find the Group of a user
The }ClientGroups cube.
mnasra
Version: 2.0
Post by mnasra »
Thank you Tomok.
So the only way, is to look into the cube and see if the intersection between the user and the group is non empty?
I want to do it in a spreadsheet. it becomes a little cumbersome.
But yes, I can do it this way.
Micheline
Micheline
mnasra wrote: ↑Fri Nov 16, 2018 10:57 pm Thank you Tomok.
Micheline
A zero-suppressed active form with }Clients as title dimension and }Groups as rows will list just the names of the groups the client is a member of.
mnasra
Version: 2.0
Post by mnasra »
ok, i have to be more specific.
the websheets checks for which sec group the user belongs to, and applies color scheme. (grey if read, white if write).
this works perfectly for all users, except one, because he belongs to 2 different groups.
I dont know how to resolve that. it works for him for group 1, but not the second.
any idea is more than welcome.
Micheline
Can you still be more specific ? How do you check the rights by group ? Do you use some kind of lookup table with a selection of groups and their associated rights ?
Mark RMBC
Version: 10.1.1
Excel Version: Excel 2010
Post by Mark RMBC »
Unless you have a million and one groups not sure why adding a simple if statement to the websheet wouldn't be the easiest way of doing this? And the colour format references the cell where the if statement is.
Lots of other ways to do this but another relatively simple alternative:
create an attribute against the client dimension and use a tI process with all relevant logic to populate the attribute as required (chore daily or something), so 0 and 1 for example. Then on the websheet use the attribute value to determine the colour format.
mnasra
Version: 2.0
Post by mnasra »
You are absolutely right Mark. I only have 5 groups, and I have an if statement in my worksheet which reads each group for my user and tests if it is empty or not.
My problem, is the one user who belongs to 2 groups. my if statement stops as soon as I get the group.
the 'temporary' solution I found, is to have 2 columns in the websheet for the each group the user belongs to. And another IF statement testing the accesses (write read none ).
It is NOT pretty, but I think it does the trick for now!
Micheline
