Hi, All
I am good with establishing name range for TM1ELLIST function with subset.
Ref: https://www.ibm.com/support/knowledgece ... llist.html
I faced challenge while establishing name range for the TM1ELLIST function through MDX.
my syntax : ( I MUST BE DOING MISTAKE WITH EXCEL SYNTAX CONSTRUCTION)
FYI : MDX syntax works perfectly in the subset expression window
construction1:
=TM1ELLIST("NewWorld:ConversionMap_Obj",,,,,"{FILTER({TM1FILTERBYLEVEL( {TM1SUBSETALL( [ConversionMap_Obj] )}, 0)},[ConversionMap].([ConversionMap_Msr].[NewDepartment]) = Sheet1!$B$3 and [ConversionMap].([ConversionMap_Msr].[NewDivision]) =Sheet1!$B$5 )}",,)
Construction2:
=TM1ELLIST("NewWorld:ConversionMap_Obj","Default","","",0,"{FILTER({TM1FILTERBYLEVEL( {TM1SUBSETALL( [ConversionMap_Obj] )}, 0)},[ConversionMap].([ConversionMap_Msr].[NewDepartment]) = "30003" and [ConversionMap].([ConversionMap_Msr].[NewDivision]) = "300081")}","","")
Can anyone through the light on the issue?
Thank You
Dharav
TM1ELLIST with MDX
Re: TM1ELLIST with MDX
First off, Sheet1!$B$3 needs to be taken I’m out of the literal string enclosed by double quotes.
dharav9
- Version: 10.3
@wim:
Removed Double Quotes:
Instead of reference to Sheet1!$b3$ , i put the value 30003
=TM1ELLIST("NewWorld:ConversionMap_Obj","Centers",,,,"{FILTER({TM1FILTERBYLEVEL( {TM1SUBSETALL( [ConversionMap_Obj] )}, 0)},[ConversionMap].([ConversionMap_Msr].[NewDepartment]) =30003 and [ConversionMap].([ConversionMap_Msr].[NewDivision]) =300081)}",,)
I am still not able to get it right. Could you please help me to understand the concept to structure the formula?
Thank You
Dharav
Thank You
Dharav
I haven’t used TM1ELLIST yet so I cannot help you in detail with this one.
dharav9
- Version: 10.3
Hi, All & Wim
i figured it out.
Cause was the construction of the MDX for the worksheet.
While referencing the cell from worksheet to MDX statement, we need to utilize
"&CHAR(34)&$b$5&CHAR(34)&" instead of just referencing cell as $b$5.
=TM1ELLIST("NewWorld:ConversionMap_Obj","Centers",,,,"{FILTER({TM1FILTERBYLEVEL( {TM1SUBSETALL( [ConversionMap_Obj] )}, 0)},[ConversionMap].([ConversionMap_Msr].[NewDepartment]) ="&CHAR(34)&$b$5&CHAR(34)&")}")
Although, following mdx statement is not working
=TM1ELLIST("NewWorld:ConversionMap_Obj","Centers",,,,"{FILTER({TM1FILTERBYLEVEL( {TM1SUBSETALL( [ConversionMap_Obj] )}, 0)},[ConversionMap].([ConversionMap_Msr].[NewDepartment]) ="&CHAR(34)&$b$5&CHAR(34)&" and [ConversionMap].([ConversionMap_Msr].[NewDivision]) ="&CHAR(34)&$b$8&CHAR(34)&")}")
do we need to use any character with "and" in the MDX for worksheet?
Thank You
Dharav
i figured it out.
Thank You
Dharav
- macsir
- Version: PAL 2.0.9
Can you use single quotes to represent string in MDX inside double quotes?
