TM1 rule using DB IF and Stet
Mark RMBC
Version: 10.1.1
Excel Version: Excel 2010
Post by Mark RMBC »
Am looking at making a TM1 model (which calculates housing rents) a little more efficient, just looking at the rules it raised my curiosity which is the best way to write a rule,
Option 1
['Formula Rent Calc A']=N:
if(NUMBR(SUBST(!Year,1,4)) > NUMBR(SUBST(!UH_Versions,1,4)),
DB('UH_Current_Year_Account_Values',!Year,!UH_Versions,!UH_House_Acc,!UH_Debit_Type,'Bed Weighting') *
DB('UH_Debit_Code_Assumptions',!Year,!UH_Versions,!UH_Debit_Type,'National Average Rent') *
DB('UH_Debit_Code_Assumptions',!Year,!UH_Versions,!UH_Debit_Type,'Relative County Manual Earnings'),STET);
Option 2
DB(if(NUMBR(SUBST(!Year,1,4)) > NUMBR(SUBST(!UH_Versions,1,4)),'UH_Current_Year_Account_Values', Stet), !Year,!UH_Versions,!UH_House_Acc,!UH_Debit_Type,'Bed Weighting')
DB(if(NUMBR(SUBST(!Year,1,4)) > NUMBR(SUBST(!UH_Versions,1,4)),'UH_Debit_Code_Assumptions', Stet), !Year,!UH_Versions,!UH_Debit_Type,'National Average Rent')
DB(if(NUMBR(SUBST(!Year,1,4)) > NUMBR(SUBST(!UH_Versions,1,4)),'UH_Debit_Code_Assumptions', Stet), !Year,!UH_Versions,!UH_Debit_Type,'Relative County Manual Earnings');
The rule is currently as per option 1 but was thinking of changing it to option 2, I doubt it will make little difference but am interested what might be considered best practice
cheers, Mark
Re: TM1 rule using DB IF and Stet
No, go for option 1. Option 2 makes very little sense actually.
Mark RMBC
Version: 10.1.1
Post by Mark RMBC »
Ok thanks Wim
bgregs
Version: 2.0
Post by bgregs »
This goes for most languages (mostly c based, but will apply here as well), try to avoid extra conditionals when possible. Depending on the case, this is sometimes unavoidable, but in your situation the extra calls in option 2 would be considered more "expensive" than the first (i.e. more "cycles" to check unnecessary conditions). Now, this isn't a resource constrained instance where we are trying to squeeze the most out of scarce memory, so always default to readability. Option 1 is much cleaner, and the guy who comes after you will greatly appreciate only having to read that conditional check once. ;)
