Hello Everyone,
I have used DBRW() in Active reports in Tm1 perspectives that gives "" when data not available for particular cell.
But same DBRW() in tm1 pax 2.0.5 version gives #Value!
Report looks bad when data not available.
Any suggestion on this. Thanks.
Tm1 pax DBRW() function
kavitha2002
- OLAP Product: tm1
- Version: 10.3.10100.8
- Excel Version: 14
Re: Tm1 pax DBRW() function
PAX is more strict than Perspectives in terms of error value vs. blank for not existing cell intersections.
You can use conditional formatting to make the font the same colour as the cell background.
kavitha2002
- OLAP Product: tm1
- Excel Version: 14
I will try with conditional formatting. Thanks
kavitha2002
- OLAP Product: tm1
- Excel Version: 14
I tried conditional formatting in excel, but in some reports problem is active reports formatting is already applied.
Say for example, White text for green background, black text white background, its dynamic based on the columns and rows changes in cube. In such a case, how to format the #VALUE! as always white. Is it possible with the conditional formatting to set "" empty string for #VAlUE, so that my problem will be solved. I hope its not possible.
Kindly get back.
Kindly get back.
Ever hear of the ISERROR function??????kavitha2002 wrote: ↑Fri Oct 12, 2018 7:36 am Is it possible with the conditional formatting to set "" empty string for #VAlUE, so that my problem will be solved. I hope its not possible.
bgregs
- Version: 2.0
+1 to tomok. Never had a desire to do this, but could you not use the infamous ";;;" and apply that to the conditional formatting as well? That would effectively make everything blank in the cell, although it would technically still be there.
