Hi Everyone,
How to get to know the number of levels in Dimension and filter the dimension elements using Level using Tm1 REST api?
Is there any option to do??
Tm1 Rest api: get number of levels in Dimension
- OLAP Product: tm1
- Version: 10.3.10100.8
- Excel Version: 14
Re: Tm1 Rest api: get number of levels in Dimension
For instance:
{{protocol}}://{{serverName}}:{{httpPortNumber}}/api/v1/Dimensions('TEST_DIM')/Hierarchies?$select=Name&$expand=Levels/$count
- OLAP Product: tm1
- Excel Version: 14
Super Wim Gielis.. Thanks for your immediate response.
Is there a way to filter the Dimension elements based on the level. For example,
{TM1FILTERBYLEVEL( {TM1SUBSETALL( [DimName] )}, 1)} in mdx do we have similar in RESTapi?
- OLAP Product: tm1
- Excel Version: 14
I have found the solution to filter the dimension elements by level, hope the below Tm1 REST api query may help someone.
http://host:8001/api/v1/Dimensions('DimName')/Hierarchies?$select=Name&$expand=Elements($select=Name,Type,Attributes,Level;$filter=Level eq 7)
