Refreshing of planning Analytics Workspace filters.
Posted: Wed Jul 25, 2018 9:14 am
Hello there, I have a question.
My problem: I have made a solution based on cognos TM1 and user interface using Planning analytics, then I made a process to rebuild cube view based on some selections in other cube.
The data refreshed and the cube created but 'The filters keep the old value, So you need to click on all filters and select the element you need based on your selection early'.
Hint: although My process set the element I want to filter int the cube filter but the workspace doen't feel. Still you need to refresh the filters.
On Architect the view was created by ti and did what I want.
Refresh means click on the filter and select your element.
Thanks in advance.
Best Regards.
Thanks in advance.
Best Regards.
