Oracle ODBC set to Cognos TM1
NAGAMANIKANTA PALURU
OLAP Product: ORACLE 11G
Excel Version: 10
Post by NAGAMANIKANTA PALURU »
Hi ,
Can you please help me how to give connection from "ORACLE database to CONGOS TM1".
If you have any documents can you please share it me.
Manikanta
Re: Oracle ODBC set to Cognos TM1
So, you want to extract data from TM1 into Oracle using ODBC? You can't. TM1 does not expose it's data via ODBC. You can extract data from a TM1 cube using ODBO. Your best bet to get data from TM1 to Oracle is to push it from the TM1 side using the TurboIntegrator tool. You can execute SQL commands from there, like INSERT, etc.
Version: PA 2.0.7
Post by jim wood »
Moved to the correct forum
