Hi Everyone,
In TM1, is there a way to get the element name using the attributes name in }ElementsAttributesCube using MDX statement.
Thanks in advance
To get the element name in dimension using the attributes name in tm1
kavitha2002
- OLAP Product: tm1
- Version: 10.3.10100.8
- Excel Version: 14
- Elessar
- OLAP Product: PA 2
- Version: 2.0.9
Re: To get the element name in dimension using the attributes name in tm1
If the attribute is alias, you can just use "{[Dimension].[AliasValue]}" and switch alias OFF in subset.
If it is not, there can be several elements with this attribute, so you can filter by this attribute: {FILTER( {TM1SUBSETALL( [Dimension] )}, [Dimension].[AttributeName] = "AttributeValue")}
