on one of the PC's in our office the TM1 Cube Viewer (Architect and Perspectives alike) behaves awkwardly.
When you save a cube view from this PC (could be any user), the width of the saved cube view is way too big (~ twice or three times the size of his screen).
From no other computer in this company we can see this behaviour.
Has anyone seen this before? Any idea what we could look into?
Our setup is Win10 with TM1 10.2.2 FP 7 FP6
Saved cube views with extremely large width
Re: Saved cube views with extremely large width
Exit Perspectives and delete the tm1p.ini file on that machine and let TM1 re-create it the next time you run Perspectives. You may have to search for it but it is usually at %USERPROFILE%\user name\AppData\Roaming\Applix\TM1\.
- Version: 10.2.2 FP7
- Excel Version: 2012
Hi Tomok,
thanks for the tip, but it did not help.
We found a workaround for this user:
-> when we attach / dock the cubeviewer window to the right side of the desktop before we save the cubeview the saved cubeview size is normal.
