Just one thing I noticed while restricting TM1 users to read-only.
There is a property in the }ClientProperties cube for that. Just set it to 1 for read only.
However, if you do this to yourself, for example being TM1 admin person, you can also remove write rights from yourself / admin persons.
I was caught like that. What helps is writing a TI process to do a CellPutN of 0 in the relevant cell of the }ClientProperties cube. Execute it and you're good again.
Wim
Warning - read only users
- jim wood
- Version: PA 2.0.7
Re: Warning - read only users
Good to know. Thanks Wim,
Jim.
Jim.
MGrain
- Version: Various
- Excel Version: Various
I've been there and done that too, caused a moment of panic!
I added a rule to the }ClientProperties cube to set myself back to zero.
tm123
- OLAP Product: tm1, cognos bi
- Version: 10.2
The other problem with Read Only Users is that the Write-Back will be completely disabled for them. I know we can't complain about this, but since in my models I usually create a cube to store User Selections and use those Selections in MDX Subsets (for example to implement Cascaded Prompts), that becomes an issue
- orlando
- Version: PAL 2.0.8
Just a quick thought about your issue.tm123 wrote: ↑Tue Jun 05, 2018 3:05 pm The other problem with Read Only Users is that the Write-Back will be completely disabled for them. I know we can't complain about this, but since in my models I usually create a cube to store User Selections and use those Selections in MDX Subsets (for example to implement Cascaded Prompts), that becomes an issue
Maybe you could "talk" to this cube via a TI (which read only users can execute). if they can't write ito a cube by the process, it should work to execute runti. the process run via runti (context of an user with hiher rights) could than handle your parameters.
tm123
- Version: 10.2
In my case, in every websheet that requires to cascade prompts, every time the user changes a SUBNM Selection, I have a DBSS that saves the Selected Member in my cube, which works perfect, and I do this not only to make the UI more user friendly, but even to avoid selection of Invalid Intersections. Doing this with a TI process, would require to have an action button clicked every time the user changes any of SUBNM selections.orlando wrote: ↑Wed Jun 06, 2018 8:00 amJust a quick thought about your issue.tm123 wrote: ↑Tue Jun 05, 2018 3:05 pm The other problem with Read Only Users is that the Write-Back will be completely disabled for them. I know we can't complain about this, but since in my models I usually create a cube to store User Selections and use those Selections in MDX Subsets (for example to implement Cascaded Prompts), that becomes an issue
It would be nice if this READ-ONLY user, does not stop the user from writing to a }Clients base cube
