I have TM1 Cam Security and configured Active Directory AP.
Active directory is always up and running but frequently disconnecting in IBM cognos.
So TM1 server explorer is not connecting
Any idea on this, and how to make it keep running all the time.
AD AP keeps disconnected in IBM cognos
kavitha2002
- OLAP Product: tm1
- Version: 10.3.10100.8
- Excel Version: 14
kangkc
- Version: 2.x
- Excel Version: 36x
Re: AD AP keeps disconnected in IBM cognos
Are you using LDAPS (ie port 636) or LDAP (port 389) for the AD in the Cognos configuration ?
If you are using LDAPS, suggest you switch to LDAP instead and see if it resolve the issue.
kavitha2002
- OLAP Product: tm1
- Excel Version: 14
I am using LDAP port 389 for AD in Cognos Configuration.
I changed the FQDN to IP address in Host and port to solve this issue. But then end up with same problem.
