Process Stuck on Zero Out
Thurston Howell III
Version: PA 2.0.8
Post by Thurston Howell III »
I have a TI process that deletes the contents of a cube and reloads the data based on a CSV. The process worked until yesterday, when it failed immediately and gave me a "stack overflow error." I deleted the Feeder files and restarted my server hoping to clear up any corrupt Feeders. Now when I run the process it gets stuck indefinitely on the prolog's VIEWZEROOUT. I have replicated the prolog below.
I am not responsible for this cube or the ones it feeds, but the person who owns them insists no rules have changed. Any ideas would be greatly appreciated.
#>>> DEFINE CUBES, VALUES AND DIMENSION ELEMENTS
strCube = 'sunHFM_Comp_Emp_Info';
strScenario = 'Budget';
strZeroNew_g = UPPER( SUBST( TRIM( pZeroNew ), 1, 1 ) );
# DEACTIVATE EMP_INFO RULES
CELLPUTS('Y', '}SunControls', 'Value', 'DeActivate EmpInfo Rules - SUN');
# ZERO OUT ALL ADP DATA
cubFin = strCube;
vewRef = 'zzzSUNZeroOut';
SubRef = vewRef;
#>>> CREATE VIEW FOR ZEROOUT
IF (VIEWEXISTS (cubFin, vewRef) = 1);
VIEWDESTROY (cubFin, vewRef);
ENDIF;
VIEWCREATE (cubFin, vewRef);
#>>> CREATE ZEROOUT SUBSET IN SCENARIO DIMENSION
dimScenario = 'bpmScenario';
strElement = strScenario;
IF (SUBSETEXISTS (dimScenario, subRef) = 0);
SUBSETCREATE (dimScenario, subRef);
ENDIF;
SUBSETDELETEALLELEMENTS (dimScenario, subRef);
SUBSETELEMENTINSERT (dimScenario, subRef, strElement, 1);
VIEWSUBSETASSIGN (cubFin, vewRef, dimScenario, subRef);
#>>> CREATE ZEROOUT SUBSET IN INDEX DIMENSION
dimIndex = 'bpmStaff_Index';
#strElement = strScenario;
IF (SUBSETEXISTS (dimIndex, subRef) = 0);
SUBSETCREATE (dimIndex, subRef);
ENDIF;
SUBSETDELETEALLELEMENTS (dimIndex, subRef);
VIEWSUBSETASSIGN (cubFin, vewRef, dimIndex, subRef);
IF(strZeroNew_g @= 'Y');
strEle = 'Total Employees';
ELSE;
strEle = 'Total Existing';
ENDIF;
p = 1;
WHILE(p <= DIMSIZ(dimIndex));
strLoopEle = DIMNM(dimIndex, p);
IF(ELLEV(dimIndex, strLoopEle) = 0 & ELISANC(dimIndex, strEle, strLoopEle) <> 0);
SUBSETELEMENTINSERT(dimIndex, subRef, strLoopEle, SUBSETGETSIZE(dimIndex, subRef) + 1);
ENDIF;
p = p + 1;
END;
#>>> PERFORM THE ZERO OUT AND DELETE VIEW
VIEWZEROOUT (cubFin, vewRef);
Re: Process Stuck on Zero Out
Note sure if it is getting unhappy here:
may be worthwhile trying:
SUBSETELEMENTINSERT(dimIndex, subRef, strLoopEle, 0);
If memory serves, I remember the 0 index adds to the end but you will need to test.
Failing this, try adding some ASCIIOUTPUTs at various places e.g. before the loop, in the loop etc. and see what gets output.
Edit: you may also want to move:
to after the loop i.e. don't assign a blank subset to the view.
BR, George.
Version: PA 2.0.7
Post by jim wood »
gtonkin wrote: Fri May 04, 2018 7:19 pm Note sure if it is getting unhappy here:
You are correct adding at position 0 adds it as the last element in the dimension and much safer than using anything else.
Thurston Howell III
Version: PA 2.0.8
Thanks for your help, guys. It was actually a rule based value issue that was preventing the zero out. It works now.
