Help on Rule in }ElementSecurity_Dimension
Posted: Mon Apr 09, 2018 3:40 pm
by Paul-TM1
I want to write a rule to apply 'READ' access to all the descendants of a hierarchy and direct ancestors above to cover the lineage on }ElementSecurity_Dimension.
Can anyone help me? I tried a few ways and don't seem to get it. I can write a TI, but is that the best solution?
In the picture attached, if I want to give access to descendants of 'Benelux' and also immediate ancestors (Europe and World). Our Dimension has many children than the attached dimension.
Paul.
Re: Help on Rule in }ElementSecurity_Dimension
Posted: Mon Apr 09, 2018 3:47 pm
by Wim Gielis
You can use the function ELISANC in the rule to determine the relations between the elements, and hence give READ access.
Posted: Mon Apr 09, 2018 4:00 pm
by tm123
You can try something like below.
I try to hardcode element names in Rules so you might have to use some mapping cube or dimension attributes to map Regions to User Groups
[ 'Group_Name' ] = S: IF ( ELISANC('DimName', !DimName, 'Benelux') = 1 % ELISANC('DimName', 'Benelux', !DimName ) = 1 % !DimName @= 'Benelux' , 'READ', 'NONE') ;
