How to add validation error message for users?
Posted: Sun Mar 18, 2018 2:57 am
by amit_hhh
I have 2 dimensions which are used in different cubes to build model, let's name them A & B. The elements of these dimensions are selected through TM1 web when users are doing planning. I have to implement a logic in such a way that while selecting the elements, one element of dimension B can be selected only for one element of dimension A. It can not correspond to multiple elements of dimension A, however one element of dimension A can correspond to multiple elements of dimension B. It's like one to many relationship. How can I implement this logic. Currently there is no look up cube in the system where such mapping exists, and I do not want to add any more cube in the system. Please suggest.
Re: How to add validation error message for users?
Posted: Sun Mar 18, 2018 7:27 am
amit_hhh wrote: ↑Sun Mar 18, 2018 2:57 am Hello,
Then you are deliberately making life difficult for yourself for no good reason. The best way to handle this requirement is to have a mapping cube holding the valid intersections of A & B.
Posted: Sun Mar 18, 2018 4:12 pm
by declanr
If the mapping will never change you can put an attribute on dimension B saying which element it maps to from A (this is really a mapping dive anyway) and/or you can have consolidations of element A in dim b but without really understanding the relationship of what these dims are it’s hard to say whether that is a good idea.
If the mapping will change between versions and/or periods then you will need a mapping cube.
Posted: Tue Mar 20, 2018 5:20 pm
by Wim Gielis
Wrong subforum, this is not an Enhancement.
Can a moderator move this thread please ?
