TM1 Active Form is returning Zeros even when suppress zero is set to True/1. Please help
Ashleigh W
- Version: TM1 Perspectives 10
- Excel Version: Excel 2016
Re: TM1 Active Form is returning Zeros even when suppress zero is set to True/1. Please help
The usual cause is that the values aren't really zero but really tiny way-down-in-the-decimal-places values, usually derived from rules. I'd slice the view in question and format Excel to show the maximum number of decimal places possible.Ashleigh W wrote: ↑Wed Mar 14, 2018 9:11 am TM1 Active Form is returning Zeros even when suppress zero is set to True/1. Please help
Ashleigh W
Thank you Alan..that answer the way tm1 might be behaving but I do not see any decimal values even if i maximize the decimal places to 20...any hack / tips for this?
Mark RMBC
- Version: 10.1.1
- Excel Version: Excel 2010
HI,
Just as a further check have you tried dividing something by the value? If it returns a div error then at least you know for sure the value is zero.
Also I presume you haven't manually changed the TM1RPTVIEW suppress zero parameter at all? If so did you rebuild the worksheet or just recalculate?
cheers, Mark
cheers, Mark
Willi
- Version: 9.5.2
Is the column in question the only column wich reference the TM1RPTVIEW-Cell? If not, all columns have to be zero that the line is suppressed.
Ashleigh W
It already has suppress enabled. I could be missing somethingMark RMBC wrote: ↑Wed Mar 14, 2018 12:15 pm HI,
cheers, Mark
=TM1RPTVIEW("server:dummyCubename:1", 1, TM1RPTTITLE("server:Version....
Ashleigh W
Willi
- Version: 9.5.2
And are both colums pretended to be zero (or empty)? If one of them is not zero/empty the line is shown
Mark RMBC
- Version: 10.1.1
Just want to know if when you open the active form in perspectives and if you do a alt-F9 to rebuild the sheet does it still show the zero values?
cheers, Mark
cheers, Mark
Ashleigh W
Yes I tried clearing the data and rebuilding it still the same. they are zeros. I tried division and it return #DIV/0! error.
I tried using public subset of level 0 for dimension still same result, tried MDX still the same.
Apologies to ask a basic question but it is actually something Willi has asked twice in this thread and unless I am missing it I can't see an answer...
is the issue that a row containing all zeroes is still showing? Or are you expecting a column containing all zeroes to be hidden?
If its the latter, active forms can only suppress rows not columns.
Again apologies if you are already aware of this but its always worth going with an Occam's razor approach to problem solving.
Willi
- Version: 9.5.2
And additionally did you checked that there is no hidden column in the form wich also references to the TM1RPTVIEW?
UserFriendly
- OLAP Product: TM1 Planning Analytics
- Version: 2.06
I had this same issue and although I am not confident this is a secure response, in my investigation I had one row suppress and the other did not. One row was a STET and the other was a Continue cell on rules. I believe it may have something to do with how TM1 reads nulls to zeroes.
I might recommend trying inserting the UNDEFVALs; in your cube rules and see what happens then and compare to see if TM1 is identifying your row cells as nulls or zeroes.
