We are trying to get users from the AD to the TM1.
Is there any way we can get the users, alias, mails (not for security).
Getting data from AD
Paul Segal
- Version: TM1 11 and up
Re: Getting data from AD
Not natively, but you can do it through e.g. VBA, VB or Powershell. Here's a sample VBA function:
The function in Excel would be along the lines of:
From there load it into an attribute.
Function Get_LDAP_User_Properties(strObjectType, strSearchField, strObjectToGet, strCommaDelimProps)
' This is a custom function that connects to the Active Directory, and returns the specific
' Active Directory attribute value, of a specific Object.
' strObjectType: usually "User" or "Computer"
' strSearchField: the field by which to seach the AD by. This acts like an SQL Query's WHERE clause.
' It filters the results by the value of strObjectToGet
' strObjectToGet: the value by which the results are filtered by, according the strSearchField.
' For example, if you are searching based on the user account name, strSearchField
' would be "samAccountName", and strObjectToGet would be that speicific account name,
' such as "jsmith". This equates to "WHERE 'samAccountName' = 'jsmith'"
' strCommaDelimProps: the field from the object to actually return. For example, if you wanted
' the home folder path, as defined by the AD, for a specific user, this would be
' "homeDirectory". If you want to return the ADsPath so that you can bind to that
' user and get your own parameters from them, then use "ADsPath" as a return string,
' then bind to the user: Set objUser = GetObject("LDAP://" & strReturnADsPath)
' Now we're checking if the user account passed may have a domain already specified,
' in which case we connect to that domain in AD, instead of the default one.
If InStr(strObjectToGet, "\") > 0 Then
arrGroupBits = Split(strObjectToGet, "\")
strDC = arrGroupBits(0)
strDNSDomain = strDC & "/" & "DC=" & Replace(Mid(strDC, InStr(strDC, ".") + 1), ".", ",DC=")
strObjectToGet = arrGroupBits(1)
Else
' Otherwise we just connect to the default domain
Set objRootDSE = GetObject("LDAP://RootDSE")
strDNSDomain = objRootDSE.Get("defaultNamingContext")
End If
strBase = "<LDAP://" & strDNSDomain & ">"
' Setup ADO objects.
Set adoCommand = CreateObject("ADODB.Command")
Set ADOConnection = CreateObject("ADODB.Connection")
ADOConnection.Provider = "ADsDSOObject"
ADOConnection.Open "Active Directory Provider"
adoCommand.ActiveConnection = ADOConnection
' Filter on user objects.
'strFilter = "(&(objectCategory=person)(objectClass=user))"
strFilter = "(&(objectClass=" & strObjectType & ")(" & strSearchField & "=" & strObjectToGet & "))"
' Comma delimited list of attribute values to retrieve.
strAttributes = strCommaDelimProps
arrProperties = Split(strCommaDelimProps, ",")
' Construct the LDAP syntax query.
strQuery = strBase & ";" & strFilter & ";" & strAttributes & ";subtree"
adoCommand.CommandText = strQuery
' Define the maximum records to return
adoCommand.Properties("Page Size") = 100
adoCommand.Properties("Timeout") = 30
adoCommand.Properties("Cache Results") = False
' Run the query.
Set adoRecordset = adoCommand.Execute
' Enumerate the resulting recordset.
strReturnVal = ""
Do Until adoRecordset.EOF
' Retrieve values and display.
For intCount = LBound(arrProperties) To UBound(arrProperties)
If strReturnVal = "" Then
strReturnVal = adoRecordset.Fields(intCount).Value
Else
strReturnVal = strReturnVal & vbCrLf & adoRecordset.Fields(intCount).Value
End If
Next
' Move to the next record in the recordset.
adoRecordset.MoveNext
Loop
' Clean up.
adoRecordset.Close
ADOConnection.Close
Get_LDAP_User_Properties = strReturnVal
End Function
=Get_LDAP_User_Properties("user","samaccountname", username,"mail")Paul
- macsir
- Version: PAL 2.0.9
if you are using Cognos namespace(CAM), then you can use Cognos SDK to export groups and users.
