tm1server.log not getting updated
supernaro
Version: 10.3
Post by supernaro »
I have observed that in one of our environments, tm1server.log is not getting updated. Information about server restart/shutdown or any process is not getting logged in it.
Is there a setting in configuration which disables updating this.
Any help is appreciated :)
Re: tm1server.log not getting updated
Confirm that you are looking in the correct location by checking the config in your TM1S.CFG
BR, George.
the technote is a little short on detail but this is your issue
http://www-01.ibm.com/support/docview.w ... wg22002669
supernaro
Version: 10.3
Post by supernaro »
gtonkin wrote: Wed Feb 14, 2018 8:49 am Confirm that you are looking in the correct location by checking the config in your TM1S.CFG
Yes I have checked that "tm1server.log" file is in the same directory as mentioned in tm1s.cfg
