2 instance 1 server
stingo
Version: 9.1 onwards
Excel Version: client dependant
2 instance 1 server
Post by stingo »
In the last 10 years, whenever I wanted to put 2 TM1 instances on the same server (say Dev and Test), I used 1 gold rule:
Change the port number/ client message port number and everything will work.
The golden rule worked till today.
Now I am probably ignoring something basic but this is the situation:
I have a dev server, 1 tm1 server for development in it. I wanted to create a test server too.
The 2 tm1 services can run mutually exclusively but they cannot cohesist, exactly as if the ports were the same.
these are the 2 cfgs
Dev
AllowSeparateNandCRules=T
CAMPortalVariableFile=portal/variables_TM1.xml
ServerCAMURI=http://LAB-SV-COGNOS01:9305/p2pd/servlet/dispatch
Language=ENG
IntegratedSecurityMode=5
ClientMessagePortNumber=19300
DataBaseDirectory=D:\TM1Servers\cxmd\data
UseSSL=T
ClientCAMURI=http://lab-sv-cognos01/ibmcognos/bi/v1/disp
DistributedPlanningOutputDir=./tunit
PortNumber=19301
ClientPingCAMPassport=900
LoggingDirectory=D:\TM1Servers\cxmd\logs
ServerName = cxmd
MTQ=6
IdleConnectionTimeOutSeconds=3600
Test
Language=ENG
ClientMessagePortNumber=19210
DataBaseDirectory=D:\TM1Servers\CXMDDEV\data
UseSSL=T
PortNumber=19211
LoggingDirectory=D:\TM1Servers\CXMDDEV\logs
ServerName = DEV
MTQ=6
A few details:
I use planning Analytics
the services have been created through cognos configurator
they run perfectly if they are in their own.
I didn't create the original CFG, I just created the second by cloning and changing ports.
I am pretty sure I am missing something dumb....
Any clue?
Thanks in advance.
kangkc
Version: 2.x
Excel Version: 36x
Re: 2 instance 1 server
Post by kangkc »
Rest API Port via the parameter :
HTTPPortNumber
If not specified, default is 5001 (PA 2.x), hence conflict.
stingo
Post by stingo »
kangkc wrote: ↑Wed Jan 17, 2018 10:24 am Rest API Port via the parameter :
HTTPPortNumber
Gotcha!
Thanks a lot.
