TM1 Replication & Synchronization
appleglaze28
Post by appleglaze28 »
Has anyone tried using the replication & tried synchronizing the data replicated sever to the source server?
I was able to replicate the cubes...but when I tried synchronizing the replicated cube from the original cube I get this error.
Sync Error.JPG (8.42 KiB) Viewed 3109 times
Then when I check the source sever, I was disconnected...this happene everytime. So does this mean, you can just replicate and no sync the data?
Steve Vincent
Version: 10.2.2 FP1
Re: TM1 Replication & Synchronization
Post by Steve Vincent »
seen that during my trials, check the SERVER event logs and trace an application error to the time you ran the replication. My issue was the dim rebuild was causing a rule issue so it never saved and threw a wobbly.
