I'm new here and a beginner with TM1, so excuse me if I get some things wrong.
I set up a Tm1 10.2.2 fp5 server to test some code on and almost everything works fine.
My Problem: I have set Max Connections of for example usr1 to "3". In my Code I execute multiple different requests to this server but over the same Client.
After the 4. request I get a 401 error because all the connection slots for this server are used.
As I understood it this shouldn't be the case. It should only take up one slot.
I'm using Restsharp but tried it with WebClient too -> same error.
What am I missing or missunderstanding?
Thanks in advance
