Hi Team,
I am encountering an issue when updating security rights within TM1 Contributor (TM1 10.2.2).
The Problem:
Application is not visible to Non admin user on contributor.
Analysis:
1.Application is getting validated successfully in Performance modeler.
2. Right are getting assigned successfully on contributor.
3. Any user assignment changes to Cognos BI Groups are updating successfully in Tm1 ‘}ClientGroups.cub’.
4. Application is not visible to non-admin user. ( }tp related control objects are not getting updated’
a. Security is not getting assigned to ‘}ElementSecurity_}tp_application.cub
(Non admin user can view the Application after updating the security manually for a single non admin user.)
b. Security is not getting assigned to }ElementSecurity_}tp_application_permission.cub.
c. Security is not getting assigned to }ElementSecurity_tp_<Approver hierarchy dimension>.cub
d.Security is not getting assigned to }CubeSecurity.cub and }dimensionSecurity.cub
Using ‘IntegratedSecurityMode=5’ and earlier the securities were applied successfully on Tm1 objects through contributor for phase 1.
Could you please suggest on above issue? As always, thanks for any feedback.
Issue updating TM1 Application (Contributor) Rights (Cognos TM1 10.2.2)
manoj30584
- Elessar
- OLAP Product: PA 2
- Version: 2.0.9
Re: Issue updating TM1 Application (Contributor) Rights (Cognos TM1 10.2.2)
Hello and welcome to the forum!
It's strange that a topic with such a good problem description is still not answered
Try to "redeploy" contributor: stop appserver, delete all "<server name="s in fpmsvc_config.xml, start appserver, open server:port/pmpsvc/ page and add your server with 5th integratedsecurity.
