Hi ,
We have static subsets disappearing in few dimension . we are not deleting any elements , while the dimension is updated we just unwind the dimension elements and re add the elements.
Also I could see the subset data in the data folder but opening up the editor showing blank for subsets.
Is this a bug in tm1 10.1.1 , we have no clue why the elements would be blank .
static subsets saved disappears
Analytics123
- OLAP Product: Tm1
- Version: 9.5
Re: static subsets saved disappears
What you are seeing is what happens when you delete elements and add them back in a TI process. You're probably not "unwinding" them like you say you are. If you are unwinding, why would you need to add them back? You just re-establish parent-child relationships.
Please try to be clear. Your subsets aren’t disappearing it’s the elements within the subsets that disappear.Analytics123 wrote: ↑Wed Nov 01, 2017 5:27 pm We have static subsets disappearing in few dimension .
- Steve Rowe
As well as the delete mentioned by Tom you can see issues in this space if you delete and recreate an alias that is being used by the subset
Analytics123
- OLAP Product: Tm1
- Version: 9.5
yes elements with in subsets are disappearing . we are not deleting the element any where .
Analytics123
- OLAP Product: Tm1
- Version: 9.5
dim update customers
first unwinding code :
DIMENSIONSORTORDER(vDim,'','','ByHierarchy','ASCENDING');
vMax = DIMSIZ(vDim);
vCount = 1;
WHILE (vCount <= vMax);
vElem = DIMNM(vDim, vCount);
vMaxParents = ELPARN(vDim, vElem);
WHILE (vMaxParents>0);
vParent = ELPAR(vDim, vElem, vMaxParents);
DimensionElementComponentDelete(vDim, vParent, vElem);
vMaxParents = vMaxParents - 1;
END;
vCount = vCount + 1;
END;
Then updating parent child relation from load file .
# Customers SoldTo
DIMENSIONELEMENTINSERT('Customers SoldTo','','All Regions','c');
DIMENSIONELEMENTINSERT('Customers SoldTo','','All Countries','c');
DIMENSIONELEMENTINSERT('Customers SoldTo','','z_Orphans','c');
DIMENSIONELEMENTCOMPONENTADD('Customers SoldTo','All Regions', 'z_Orphans',1.000000);
DIMENSIONELEMENTCOMPONENTADD('Customers SoldTo','All Regions',SoldToRegion,1.000000);
DIMENSIONELEMENTCOMPONENTADD('Customers SoldTo',SoldToRegion,SoldToDist,1.000000);
DIMENSIONELEMENTCOMPONENTADD('Customers SoldTo',SoldToDist,vSoldToSubRegion,1.000000);
DIMENSIONELEMENTCOMPONENTADD('Customers SoldTo',vSoldToSubRegion,SoldToRep,1.000000);
DIMENSIONELEMENTCOMPONENTADD('Customers SoldTo',SoldToRep,SoldToCustomer,1.000000);
DIMENSIONELEMENTCOMPONENTADD('Customers SoldTo',SoldToCustomer,ShipToCustomer,1.000000);
Thats the code we have .
vCount = 1;
END;
END;
# Customers SoldTo
Are you sure? Like really, REALLY sure? Because if elements are being removed from a static subset (which isn't being edited in any way), then the only way that is happening is if the elements are being deleted and then re-added to the dimension. Have you double (and triple) checked that there isn't any other process also editing the same dimension?
Also much better practice to loop backwards from max to 0 whenever removing items from a list.
