Problem after upgrading from TM1 10.2.2 to 10.3
jack_008
Version: 10.3
Excel Version: Excel 2013
Post by jack_008 »
We have recently upgraded from TM1 10.2.2 to TM1 10.3
We are transferring data from one cube to other.The problem we are facing is the cell values in a target cube are unclear for e.g.
330 displays as 3300(Here 330 is the value in source cube & the value in the target cube appears to be 3300)
Similar situation for other records below.
600000 as 59999999999999000
20000 as 20000000000000000
71461 as 71461000000000000
80000 as 79999999999999000
Can anyone help me out with this issue.
Thanks in advance !
Re: Problem after upgrading from TM1 10.2.2 to 10.3
Obviously sounds odd, have you checked if you have a formatting issue? Which client environment are you seeing the issue and what formatting is in place?
If you look in the transaction log what value is being written to the cube?
jack_008 wrote: Wed Nov 01, 2017 1:46 pm We have recently upgraded from TM1 10.2.2 to TM1 10.3
What exactly do you mean by TM1 10.3? As far as I am aware no such version exists. "10.3" was used to refer to the server version of the 1st iteration of Planning Analytics cloud and AFAIK exist only in the cloud version and is not available on premise (and never will be). Planning Analytics Local is TM1 v11.
pandinus
Post by pandinus »
Since TM1 10.2.2 FP6 (and also in Planning Analytics 2.x) there is an issue (IBM calls this a feature) with the StringToNumber functionality in some cases where a specific decimal-separator is defined on the server OS level.
This may be the cause for what you are seeing right now.
The solution that IBM provides technically isn't a solution, but rather a workaround. By using NValue instead of StringToNumber the correct data will be transferred to the target cube.
