Hi ,
we are in 10.1.1 and our process defined in chore starts 2 mins later than the scheduled time . IS there a setting that is controlled or a bug . It happens only recently .
TM1 process in chore starts with 2 min delay
Analytics123
- OLAP Product: Tm1
- Version: 9.5
- jim wood
- Version: PA 2.0.7
Re: TM1 process in chore starts with 2 min delay
Are there any other chores running at the time? Are there any meta updates happening? Have you checked top (or whatever the modern fangled thingie is) when it is happening to see if anything else is running?
- Steve Rowe
Also check the time on the server is the same as the time on the client. I suspect what you are seeing is just a time difference between the client and the server.
