MDX using TI Parameters
RonLat
OLAP Product: TM1, Planning Analytics
Version: 2.0
Excel Version: 365
Post by RonLat »
using a MDX statement, it is possible to create a subset by filtering the values of a cube. However, it is necessary to explicitly name the dimensions and elements of the cube. In my case, the [Period] and [Config_Measure].[Source] are constants in the MDX statement below. I'd like to vary the elements [Year].[FY17] and [Scenario_Plan].[FC0517], because I need the process to create different subsets for [Period] in dependence of the selected elements in the dimension [Year] and [Scenario_Plan]. Is there any possibility to use TI Parameters as variables for the selection of the elements? If not, any idea how to solve this problem?
SubsetCreateByMDX (SubNameSRC,
'{FILTER({TM1FILTERBYLEVEL(
{TM1SUBSETALL( [Period] )}, 0)},
[Config_JPS].( [Year].[FY17], [Scenario_Plan].[FC0517], [Config_Measure].[Source]) > 0 )}'
Re: MDX using TI Parameters
Yup, just concatenate the vars into the MDX string
sMDX='{FILTER({TM1FILTERBYLEVEL(
[Config_JPS].( [Year].[' | sYear |'], [Scenario_Plan].[' | sScenario |'], [Config_Measure].[Source]) > 0 )}'
SubsetCreateByMDX (SubNameSRC, sMDX);
tm123
OLAP Product: tm1, cognos bi
Post by tm123 »
RonLat wrote: Mon Oct 30, 2017 11:37 am using a MDX statement, it is possible to create a subset by filtering the values of a cube. However, it is necessary to explicitly name the dimensions and elements of the cube. In my case, the [Period] and [Config_Measure].[Source] are constants in the MDX statement below. I'd like to vary the elements [Year].[FY17] and [Scenario_Plan].[FC0517], because I need the process to create different subsets for [Period] in dependence of the selected elements in the dimension [Year] and [Scenario_Plan]. Is there any possibility to use TI Parameters as variables for the selection of the elements? If not, any idea how to solve this problem?
You just assign the MDX statement to a String Variable and then you concatenate the Static Part of your MDX with the variable part.
sMDX = '{FILTER({TM1FILTERBYLEVEL(
[Config_JPS].( [Year].[‘ + pYear + ‘], [Scenario_Plan].[FC0517], [Config_Measure].[Source]) > 0 )}' ;
I am typing from a Cell Phone and I cannot find the pipe character so I used + instead of pipe for concatenating strings
Then in your SubsetCreateByMDX use the sMDX variable
SubsetCreateByMDX (SubNameSRC, sMDX );
PavoGa
Excel Version: 2013 PAW
Post by PavoGa »
To make the code easier to read, I switched to this:
strMDX = EXPAND('UNION( {[%dimName%].currentmember}
    , FILTER( TM1SUBSETALL( [%dimName%] )
       ,  [%cubName%].([%dimName1%].[%element%], ...) = %pParam1%)
    , ALL)');
SubsetCreateByMDX(subName, strMDX);
SubsetElementDelete(dimName, subName, 1);
In this example, the dimensions, cube and elements are stored in variables. It is a lot easier to read, especially on more complex MDX, than the concatenation method.
Ty
Cleveland, TN
