Hi, I have a simple report cube which:
1. Has no rule
2. Values (rounded to 2 decimal places by TI) are put in by a TI process from another cube.
Issue: Some consolidated cells show a negligible value (e.g. 0.000000000000013) when the children cells are added to a perfect $0.00 and therefore should be suppressed.
Is there any solution to this? Can I use a rule to round a consolidated cell without using too much resource?
Thanks.
Kenneth
Negligible value in consolidation
BariAbdul
- Version: PAW 2.0.8
- Excel Version: 2019
Re: Negligible value in consolidation
Have you tried formatting the numbers:
https://goo.gl/PT54d8 Thanks
Duncan P
- Version: 9.5.2 10.1 10.2
- Excel Version: 2003 2007
If you are interested in why it happens then have a read of this.
The effect is magnified in consolidated numbers and the level of error increases the more leaf numbers are involved.
