TM1 Tip - Parallel Processing with tm1runti
tiagoblauth79
OLAP Product: Cognos BI and TM1
Excel Version: 10
Post by tiagoblauth79 »
Hi. I did create a code for parallel processing in TM1, based on tm1runti.exe. With this code, TM1 can run multiple processes at the same time. You can define how many processes you want to run in parallel and the code triggers as many tm1runti is requested. So, when one process is ready, tm1runti takes another process in the list to run, until all requested processes are ready.
Objects and instructions in the attached file. Enjoy :)
WINDM.zip
TM1 Objects and Readme
(304.46 KiB) Downloaded 1396 times
Version: PA 2.0.7
Re: TM1 Tip - Parallel Processing with tm1runti
Post by jim wood »
Moved this post to useful code, tips and tricks as it will be easily visible for longer.
