I need to write a rule to apply an excahge rate. I was wondering how to write the area to include the elements of a consolidation without having to include all elements. Below is the syntax I am currently using. I would like to shorten it if possible.
['5080','5090','5091','5093','US$','Actual'] = N:IF(numbr(!Financial Accounts)>290000,(DB('Financials', !CoCost, !Financial Accounts, !Version, !Departments, !Month, 'CD$')/DB('Exchange Rate','CDA AVERAGE EXCHANGE RATE',!Month)),0);
There are many more costcenters than what is shown above. I want to include all elements of
"C0 50 Canada" without having to input them all into the area of the rule. Is there a way to do this?
Thank you,
Mark
Syntax for Area in Rule
- Version: 10.1.1
TM1 version 9.1 using excel 2003
- Martin Ryan
Re: Syntax for Area in Rule
The answer is in "elisanc" i.e. elisanc('Dimension', !Elem, 'Consolidation')"
['US$','Actual'] = N:IF(elisanc('CoCost', !CoCost, 'C0 50 Canada'),(DB('Financials', !CoCost, !Financial Accounts, !Version, !Departments, !Month, 'CD$')/DB('Exchange Rate','CDA AVERAGE EXCHANGE RATE',!Month)),continue);
HTH,
HTH,
- Version: 10.1.1
Thanks. I will try that. How about having the exchange rate only calculte for the month and then the consolidated element will ne the sum of the months for a YTD?
Thanks again,
Mark
Thanks again,
Mark
- Martin Ryan
That will happen automatically because your rule says "N:" this means the rule is only applied at the leaf (N) level, and that consolidations will still be consolidations.
To make the rule apply to everything, N and C level regardless, remove the "N:".
To make a rule apply only to C level, make the N: a C:
- Version: 10.1.1
That is what I was hoping would happen so I will just leave in the N:. Thanks again for the help.
- Eric
- Version: 9.4
- Excel Version: 2003
Try['5080','5090','5091','5093','US$','Actual']
[{'5080','5090','5091','5093'},'US$','Actual']
Eric
Eric
