Not Fed issue
Posted: Wed Sep 13, 2017 9:41 pm
Hello all.
I was suppose to relax and watch football but instead thinking about intersections that are not fed. So I have two cubes, one which is the data cube, second which is analysis cube.
Previously I had used a TI that allowed me to input numeric values against any periods that were between start and end date. That worked smoothly. And I was thinking I may as well just use that mechanism again for a similar analysis but then thought of trying the rule method. Now with that method, when I suppress zeros, I am losing all but 2 of my numeric analysis thats between the two trimmed dates but the number against the start date and end date stay as they are fed. How do I make it so that all the numbers between the dates also stay and are fed? So when I suppress zeros, Il have those numbers.
Thank you in advanced
