We are thinking about creating a new TM1 role called "Super"that has access to all our 90k+ cost centres but not utilizing the admin licences.
Is there a quicker way to give write access to all 0 level element in the cost centres dimension then just copy and paste "write" to all? I tried and my computer froze for a very long time, had to kill the task eventually.
Please advise.
YYround
TM1 super user
Re: TM1 super user
You could easily do that through Rules but I'm not a fan of using Rules for element security. I don't feel that the benefit that you get from it is worth the calculation overhead, though I have used them in the past and if I had a constantly changing dimension I might consider it in the future.yyround wrote: ↑Mon Aug 28, 2017 1:41 am We are thinking about creating a new TM1 role called "Super"that has access to all our 90k+ cost centres but not utilizing the admin licences.
Please advise.
My preferred method is to use an overnight TI (which can also be run during the day) to update the security based on a control cube. However you don't even need to go to that extent; you could just write a simple process to iterate the elements and assign Write to the SuperUser group.
yyround
- Version: PA2.0.8
- Excel Version: MS 2016
Re: TM1 super user
Thanks Alan,
Much appreciated:)
YYround
Much appreciated:)
YYround
