HierarchySize Function
Anyone seen the equivalent of DimSiz for Hierarchies?
HierarchySize or HierarchySiz doesn't compile and I can't see any other likely candidates.
Anyone spotted the function?
BrianL
Version: 9.5.2 10.1 10.2 PA2
Re: HierarchySize Function
Post by BrianL »
Have you tried passing 'DImensionName:HierarchyName' into DimSiz?
st2000
OLAP Product: TM1 (Windows) & SSAS 2014 Ent.
Version: 10.2.0 FP3
Excel Version: Excel 2013
Post by st2000 »
In the PA docs there are many functions supporting the new hierarchy feature, maybe this could do the job?
HierarchySubsetGetSize(DimName, HierName, SubsetName);
As far as there is a subset ALL in place for the regraded hierarchy...
Stefan
Post by David Usherwood »
Digging in somewhat it turns out that DIMSIZ is a rules function (which can be used in TI like almost all of them) - clue is that it is short and cryptic.
This can be done with Marius Wirtz' TM1py libraries:
from TM1py.Services import TM1Service
with TM1Service(address='', port=8045, user='', password='', ssl=True) as tm1:
    dim_name = 'SDK.Geography'
    dimension = tm1.dimensions.get(dimension_name=dim_name)
    # iterate through hierarchies
    for hierarchy in dimension:
         print(hierarchy.name, len(hierarchy))
(Updated 25/08 - no need for an explicit loop)
BrianL wrote: Wed Aug 23, 2017 3:17 pm Have you tried passing 'DImensionName:HierarchyName' into DimSiz?
Thanks Brain, I can confirm that DimSiz ('DImensionName:HierarchyName' ) returns the correct information...
