How to prevent Active Form File Load Refresh
Ashleigh W
Version: TM1 Perspectives 10
Excel Version: Excel 2016
Post by Ashleigh W »
Hi everyone,
As soon as excel File Loads Active Form starts refreshing all the sheets with ActiveForm which takes time.
is there a way to prevent it from refreshing on load? I have already set the calculation mode to manual still it calculates on load.
thank you.
Re: How to prevent Active Form File Load Refresh
Have a look at the named ranges in the workbook. There should be one called TM1REBUILDOPTION. Update the value to 0 (zero). If there is not one, create it to be safe, scoped as workbook, and assign it a value of 0.
If this is happening on TM1 Web, there are other avenues that need to be explored.
BR, George.
Ashleigh W
thank you for quick answer. I'll try and get back.
Ashleigh W
Works perfect. Thank you gtonkin
