is python is used in Planning analytics(10.3)??
MariusWirtz
- Version: 10.2.2.6
Re: is python is used in Planning analytics
no, PA doesn't support the Python programming language natively.
The Planning Analytics Server (TM1) has a REST API though. It's powerful and ligthning fast.
So you can relatively easily do Python stuff with your Planning Analytics model.
In case you want to do that, we built an open source Python wrapper around the TM1 REST API.
https://github.com/MariusWirtz/TM1py
It makes things a lot easier and it's (almost entirely) documented and tested.
Happy python-ing! Cheers,
Marius
Marius
vinod
- OLAP Product: IBM TM1
- Excel Version: Excel2013
Tq marius,can you tell me the difference between tm1s.cfg file and tm1p.ini file. Thanks in advance
ellissj3
- Version: 9.0 - 10.2
Vinod,
This should be a different thread, and it does not follow the posting guidelines.
TM1S.CFG - Server configuration file which dictates the operations of the TM1 server itself
TM1P.INI - User configuration file
george_apo
- OLAP Product: Planning analytics
- Version: 2.0.26 (Cloud)
did anyone manage to use python to connect to planning analytics (cloud) with single sign on, via the REST API?
I have been working with Marius and with Jason Kapp to adjust TM1PY to work with TM1 SaaS. Marius has released a new version which should handle this but I have not yet tested it myself. I suggest you download it and try, and let him know at https://github.com/cubewise-code/TM1py how you get on - we'd all be interested
george_apo
Ok thanks
I will give it a try
