tm1s.cfg performance parameters
| Area | Function | Brief Description |
| Performance | AllRuleCalcStargateOptimization | When AllowSeparateNandCRules=T, it can improve performance in calculating views that contain only rule-calculated values. Minimal time consumption to other views. |
| Performance | CalculationThresholdForStorage | Defines a minimum number of rule calculations required for a single cell or Stargate view, beyond which the server stores the calculations for use during the current server session. High parameter decrease memory but is slowest, low parameter increases memory and is fastest. Default is 50. |
| Performance | CheckFeedersMaximumCells | Limits the number of cells checked by the Check Feeders option in the Cube Viewer. It increases performance to large applications. Default is 3,000,000 |
| Performance | DisableWorksheetView | You should disable the worksheet VIEW functions when you work with extremely large row or column dimensions in slice worksheets. DisableWorksheetView=T |
| Performance | JobQueueMaxWaitTime | When the queue thread runs, it blocks all incoming requests to ensure it can get the locks necessary to process a job on the queue. To give the queue thread higher priority, set the JobQueueMaxWaitTime to a larger number. Defaults to 100ms. |
| Performance | JobQueueThreadSleepTime | JobQueueThreadSleepTime determines the frequency with which the thread processing the queue runs when there are queued jobs. Defaults to 10 seconds. |
| Performance | JobQueueThreadPoolSize | Enables TM1 to use multiple threads on sandbox request. |
| Performance | LockPagesInMemory | When LockPagesInMemory=T, Windows trims pages from the TM1 process space, but does not page them to disk. Windows 64-bit only. |
| Performance | MaximumCubeLoadThreads | Specifies whether the cube load and feeder calculation phases of server loading are multi-threaded, so multiple processor cores can be used in parallel. If your Cognos TM1 model uses conditional feeders where the condition clause contains a fed value you should not use this. Best set is process chores -1 |
| Memory consumption | MaximumMemoryForSubsetUndo | Sets the maximum amount of memory, in kilobytes, to be dedicated to storing the Undo/Redo stack for the Subset Editor. Default is 10240 kilobytes (10 MB). |
| Performance | PersistentFeeders | To improve reload time of cubes with feeders, set to T. Using the Persistent Feeders feature will increase your system size on disk only. Memory size is not affected by the use of this parameter. |
| Server load time | PrivilegeGenerationOptimization | When this parameter is set to T, the TM1 server will read only the populated cells in security cubes. In the case of a sparsely populated security cube, this will dramatically shorten the server's load time. |
| Server load time | SkipLoadingAliases | Use SkipLoadingAliases to speed up the loading of the server and updating of views by skipping the loading of aliases. Check support if you can use it. |
| Performance | SubsetElementBreatherCount | This parameter manages the way it handles locking behavior for subsets. SubsetElementBreatherCount=-1 (standard) better for single access SubsetElementBreatherCount=0 better for concurrent access |
| Performance | ViewConsolidationOptimizationMethod | This parameter defines the method used to achieve view consolidation optimization. It should be set to TREE in most circumstances. Two methods: TREE (for tree aggregations) and ARRAY (for multiple aggregations). Default is ARRAY. |
tm1p.ini performance parameters
| Performance | DimensionDownloadMaxSize | To improve performance when you work with large dimensions, add DimensionDownloadMaxSize so that large dimensions will cache on the client. |
