Can i take 2016 user logon details from tm1 server? I checked in View Audit Log and given one year, but it is not executing. it gives output only for the recent ten days.
Where I can find this information from the TM1 server?
kkmk
TM1 user logon details
- tiagoblauth79
- OLAP Product: Cognos BI and TM1
- Excel Version: 10
Re: TM1 user logon details
Check if you have "MaxBackupIndex" set in tm1admsrv-log.properties. If it is set, the audit log is being erased when it reaches the number of files. The AuditLogMaxFileSize parameter in the tm1s.cgf determines the size of each file size, then TM1 breaks it in more files. Transaction log displays the transactions recorded when a cube value is changed, so you can check who did changes in the data. Perhaps you still have it and it may help you.
