TM1 web hanging after triggering a long run process
macsir
Version: PAL 2.0.9
Post by macsir »
Basically if I trigger a long run (eg 40 minutes)ti process from tm1web, web is always hanging even after it finishes successfully in the back end already. The web is responding to any clicking. This happens to PA web as well. Any idea?
Re: TM1 web hanging after triggering a long run process
Have you tried changing your timeouts across TM1 and TM1Web. Could be due to perceived inactivity.
BR, George.
macsir
Version: PAL 2.0.9
Post by macsir »
I have changed tm1web session from 20 minutes to 2 hours. Still the same.
Did you review "IdleConnectionTimeOutSeconds" in your TM1s.cfg too?
BR, George.
macsir
Version: PAL 2.0.9
Post by macsir »
The process is running all the time and it is just the web which lost return status from the process in the end. I don't this parameter is relevant. :|
macsir wrote: Thu Jul 20, 2017 1:11 pm The process is running all the time and it is just the web which lost return status from the process in the end. I don't this parameter is relevant. :|
I think a client session that is just sitting there waiting on a process finish status is considered "idle".
macsir
Version: PAL 2.0.9
Post by macsir »
tomok wrote: Thu Jul 20, 2017 2:05 pm
Alright, tomok. I will try it later if you say so.
