Datapoint Value Accuracy
Posted: Wed Aug 05, 2009 3:08 pm
Not sure if you'd call this a bug or a feature. I have a cube where a consolidated value is a whole number but its children get split in decimals, down to about 6dp, to get it spot on. I needed to change the consolidation keeping the proportional spread of its children the same, so i used data spreading to do that and it all worked fine.
As i had about 15 to do, and 2 sets of years for each, i decided to copy the values and paste them over all the others. The cube view was formatted to 0dp and so i was surprised when i recalculated it to see the end value was 1768 and not 1770 as required.
I know what its doing, i'm just bemused as to why. When it copies the data all it picks up is the formatted value, not the underlying full value. Thats different to how Excel works where even if the data is formatted to 0dp, the value stored is the original 6dp or whatever it was.
Is that the same in later versions of TM1, and is that how others feel it should work? To me that's wrong, it should be the same as Excel especially where it has such high integration between the 2. Its one of those things that you get so used to it working one way that you never give it 2 thoughts in a different system, and in the end just causes more work.
1,770.000000 136.233061 136.147245 170.184056 136.147245 136.147245 170.184056 136.147245 136.147245 170.184056 136.147245 136.147245 170.184056Code: Select all
1,768 136 136 170 136 136 170 136 136 170 136 136 170Is that the same in later versions of TM1, and is that how others feel it should work? To me that's wrong, it should be the same as Excel especially where it has such high integration between the 2. Its one of those things that you get so used to it working one way that you never give it 2 thoughts in a different system, and in the end just causes more work.
